Hi there! I am trying to install pi-hole on a debian server but cant seem to get it going continusly just ending mid install.
not installing or run
9uvzbqdj1k
9uvzbqdj1k
Let's reset the nameserver for the Pi and then repair:
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run pihole -r and select repair.
did not work ![]()
Here is the config file:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver fe80::ea94:f6ff:fee2:e7fc%enp3s0
nameserver 9.9.9.9
search lan
What did not work? Were you not able to complete a repair? If so, what was the output of the repair command?
Ends with this
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved does not need to be restarted
[i] Restarting lighttpd service...
What are the outputs of the following:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
sudo service lighttpd status
> Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
> tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 26990/pihole-FTL
> tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 26990/pihole-FTL
> tcp6 0 0 ::1:4711 :::* LISTEN 26990/pihole-FTL
> tcp6 0 0 :::53 :::* LISTEN 26990/pihole-FTL
> udp 0 0 0.0.0.0:53 0.0.0.0:* 26990/pihole-FTL
> udp 0 0 127.0.0.53:53 0.0.0.0:* 25737/systemd-resol
> udp6 0 0 :::53 :::* 26990/pihole-FTL
> ● lighttpd.service - Lighttpd Daemon
> Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
> Active: failed (Result: exit-code) since Tue 2019-02-12 18:11:43 CET; 7min ago
> Process: 2798 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
> Main PID: 12738 (code=exited, status=0/SUCCESS)
> Feb 12 18:11:42 Oklahoma systemd[1]: lighttpd.service: Control process exited, code=exited status=255
> Feb 12 18:11:42 Oklahoma systemd[1]: Failed to start Lighttpd Daemon.
> Feb 12 18:11:42 Oklahoma systemd[1]: lighttpd.service: Unit entered failed state.
> Feb 12 18:11:42 Oklahoma systemd[1]: lighttpd.service: Failed with result 'exit-code'.
> Feb 12 18:11:43 Oklahoma systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
> Feb 12 18:11:43 Oklahoma systemd[1]: Stopped Lighttpd Daemon.
> Feb 12 18:11:43 Oklahoma systemd[1]: lighttpd.service: Start request repeated too quickly.
> Feb 12 18:11:43 Oklahoma systemd[1]: Failed to start Lighttpd Daemon.
> Feb 12 18:11:43 Oklahoma systemd[1]: lighttpd.service: Unit entered failed state.
> Feb 12 18:11:43 Oklahoma systemd[1]: lighttpd.service: Failed with result 'exit-code'.
This thread may have a solution to your problem:
Did not work even with chown 777
> Active: failed (Result: exit-code) since Tue 2019-02-12 18:54:25 CET; 380ms ago
> Process: 5220 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
> Feb 12 18:54:25 Oklahoma systemd[1]: lighttpd.service: Unit entered failed state.
> Feb 12 18:54:25 Oklahoma systemd[1]: lighttpd.service: Failed with result 'exit-code'.
> Feb 12 18:54:25 Oklahoma systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
> Feb 12 18:54:25 Oklahoma systemd[1]: Stopped Lighttpd Daemon.
> Feb 12 18:54:25 Oklahoma systemd[1]: lighttpd.service: Start request repeated too quickly.
> Feb 12 18:54:25 Oklahoma systemd[1]: Failed to start Lighttpd Daemon.
What is the output of journalctl -u lighttpd -l
This is it
> -- Logs begin at Tue 2019-02-12 15:32:21 CET, end at Wed 2019-02-13 00:28:07 CET. --
> Feb 12 17:30:37 Oklahoma systemd[1]: Starting Lighttpd Daemon...
> Feb 12 17:30:37 Oklahoma systemd[1]: Started Lighttpd Daemon.
> Feb 12 17:30:59 Oklahoma systemd[1]: Stopping Lighttpd Daemon...
> Feb 12 17:30:59 Oklahoma systemd[1]: Stopped Lighttpd Daemon.
> Feb 12 17:30:59 Oklahoma systemd[1]: Starting Lighttpd Daemon...
> Feb 12 17:30:59 Oklahoma lighttpd[19640]: /bin/sh: 1: /usr/share/lighttpd/create-mime.assign.pl: not found
> Feb 12 17:30:59 Oklahoma lighttpd[19640]: 2019-02-12 17:30:59: (configfile.c.1461) command "/usr/share/lighttpd/create-mime.assign.pl" exited no
> Feb 12 17:30:59 Oklahoma lighttpd[19640]: 2019-02-12 17:30:59: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 53 pos: 14 parser f
> Feb 12 17:30:59 Oklahoma systemd[1]: lighttpd.service: Control process exited, code=exited status=255
> Feb 12 17:30:59 Oklahoma systemd[1]: Failed to start Lighttpd Daemon.
> Feb 12 17:30:59 Oklahoma systemd[1]: lighttpd.service: Unit entered failed state.
> Feb 12 17:30:59 Oklahoma systemd[1]: lighttpd.service: Failed with result 'exit-code'.
> Feb 12 17:31:00 Oklahoma systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
> Feb 12 17:31:00 Oklahoma systemd[1]: Stopped Lighttpd Daemon.
> Feb 12 17:31:00 Oklahoma systemd[1]: Starting Lighttpd Daemon...
> Feb 12 17:31:00 Oklahoma lighttpd[19648]: /bin/sh: 1: /usr/share/lighttpd/create-mime.assign.pl: not found
> Feb 12 17:31:00 Oklahoma lighttpd[19648]: 2019-02-12 17:31:00: (configfile.c.1461) command "/usr/share/lighttpd/create-mime.assign.pl" exited no
> Feb 12 17:31:00 Oklahoma lighttpd[19648]: 2019-02-12 17:31:00: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 53 pos: 14 parser f
> Feb 12 17:31:00 Oklahoma systemd[1]: lighttpd.service: Control process exited, code=exited status=255
> Feb 12 17:31:00 Oklahoma systemd[1]: Failed to start Lighttpd Daemon.
> Feb 12 17:31:00 Oklahoma systemd[1]: lighttpd.service: Unit entered failed state.
> Feb 12 17:31:00 Oklahoma systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Have you modified /etc/lighttpd/lighttpd.conf? Also, the output you shared cuts off some lines, please share the full lines.
