threej
March 12, 2019, 9:21pm
1
Pi-hole IP entered in router DNS does not break internet connection; Pi-hole IP entered in computer DNS blocks ads.
Pi-hole IP, entered in router's DNS breaks internet connection. Pi-hole IP entered in computer DNS does not break internet connection but allows ads.
jfb
March 12, 2019, 9:35pm
2
Your debug log shows that Pi-Hole is working properly and listening for DNS queries on its ethernet connection at IP 10.0.1.7. Is this the IP you have entered in the router and client?
Three methods
Generally, there are three different methods that will enable devices on your network to be protected by Pi-hole.
1. Define Pi-hole's IP address as the only DNS entry in the router
Rationale
Only is italicized here for a reason: Pi-hole needs to be the only DNS server because it intercepts queries and decides whether or not they should be blocked. If you have other DNS servers configured, you may be sent to the correct domain, bypassing Pi-hole completely.
Because of this, we re…
threej
March 12, 2019, 9:47pm
3
jfb, that is the correct IP. Strangely, I shut down and moved the Pi to another location in my home where I intend headless use — and when powered up entered its IP in my router again as a test, and, for whatever reason, it worked.
No idea why, but it’s working now.
system
Closed
April 2, 2019, 9:47pm
4
