Blocklist not removable
I did ad a local (intranet) blocklist made a type and want o remove the list but thats not possible. did clik on the trahscan it shows is wil be removed but once i click save or update and save its not removed. Did alse several reboots the list wil not remove
edit /etc/pihole/adlists.list, that is where the lists are stored.
You can use either putty or winscp or …
Don't know how to use putty and winscp? Explained in detail here.
You need to run pihole -g after the edit has been saved.
Not working, keep getting no permissions
Removed te file and put a new url in the web interface, and there is the file again….
But its not anymore possible to put in a local networked blacklist
I don't use a local networked blacklist, I do put a file in /var/www/html, for example /var/www/html/mylist.txt and add http://localhost/mylist.txt as the blacklist to process.
Workaround?
Don't know if this is related, took me a while to find it. maybe this helps.
Not working for me. It works before in an old version of Pihole. An i want it working because its a professional list of 1153010 banned sites J and upadated every day. That’s not to do by hand. And not possible to connect like Pi-hole.
I can try to put te list on my local webserver. (I have and AD network SRV 2012R2) and make a secure connection that no problem but i doubt if that’s the solution
I already didi that and the pihole finds an empty file, put it also on a webserver and give all rigths to everyone, just to test p-) (1153010 entries) mayby to big ?
Did \websrv\websites\intranet\lists and file://websrv/websites/intranet/lists/host.txt
Strange because it worked in older versions
May need some professional help here... @DL6ER: any ideas?
What is the output when you run the command
ls -lh /etc/pihole
on your Pi-hole machine?
pi@PiHole:~ $ ls -lh /etc/pihole
total 24M
-rw-r--r-- 1 root root 395 Dec 13 10:43 adlists.list
-rw-r--r-- 1 root root 2.4K Dec 13 16:11 black.list
-rw-r--r-- 1 root root 2.4K Dec 9 09:52 blacklist.txt
-rw-r--r-- 1 root root 2 Dec 13 18:23 GitHubVersions
-rw-r--r-- 1 root root 3.0M Dec 13 16:11 gravity.list
-rw-r--r-- 1 root root 1.3K Dec 12 19:50 install.log
-rw------- 1 root root 1.9M Dec 13 16:11 list.1.raw.githubusercontent.com.domains
-rw------- 1 root root 582K Dec 13 10:44 list.2.mirror1.malwaredomains.com.domains
-rw------- 1 root root 7.1K Dec 13 10:44 list.3.zeustracker.abuse.ch.domains
-rw------- 1 root root 613 Dec 13 10:44 list.4.s3.amazonaws.com.domains
-rw------- 1 root root 43K Dec 13 10:44 list.5.s3.amazonaws.com.domains
-rw------- 1 root root 1.7M Dec 13 10:44 list.6.hosts-file.net.domains
-rw-r--r-- 1 root root 3.0M Dec 13 16:11 list.preEventHorizon
-rw-r--r-- 1 root root 20 Dec 13 18:30 localbranches
-rw-r--r-- 1 root root 41 Dec 13 16:11 local.list
-rw-r--r-- 1 root root 37 Dec 13 18:30 localversions
-rw-r--r-- 1 root root 234 Dec 12 19:49 logrotate
-rw-rw-r-- 1 pihole pihole 15 Dec 12 19:50 pihole-FTL.conf
-rw-r--r-- 1 pihole pihole 14M Dec 13 18:34 pihole-FTL.db
-rw-rw-r-- 1 pihole www-data 0 Dec 13 10:49 regex.list
-rw-r--r-- 1 root root 424 Dec 13 14:28 setupVars.conf
-rw-r--r-- 1 root root 402 Dec 12 19:49 setupVars.conf.update.bak
-rw-r--r-- 1 root root 118 Dec 6 11:16 whitelist.txt
-rw-r--r-- 1 root root 0 Dec 6 11:16 whitelist.txt.bck~
pi@PiHole:~ $
