Blocked https links stall for 20 seconds
block https scripts imediately
https scripts time out after 22 seconds
tmh7xp4gk3
i'm having problems with pages that have blocked https links on them, the page stalls for about 22 seconds on them before returning status failed in the chrome debugger.
I have read Why do some sites take forever to load when using Pi-hole? (for versions < v4.0) and applied the iptables mentioned in there:
pi@raspberrypi:~ $ sudo iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
REJECT     tcp  --  anywhere             anywhere             tcp dpt:https reject-with tcp-reset
REJECT     udp  --  anywhere             anywhere             udp dpt:80 reject-with icmp-port-unreachable
REJECT     udp  --  anywhere             anywhere             udp dpt:443 reject-with icmp-port-unreachable
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
pi@raspberrypi:~ $ sudo ip6tables -L
REJECT     tcp      anywhere             anywhere             tcp dpt:https reject-with tcp-reset
REJECT     udp      anywhere             anywhere             udp dpt:80 reject-with icmp6-port-unreachable
REJECT     udp      anywhere             anywhere             udp dpt:443 reject-with icmp6-port-unreachable
but this changes nothing. Is there anything else i could be missing?
Thanks!!
After posting this i found this link that if i understand it correctly says that my ipv6 address chagned: Use IPv6 ULA addresses for Pi-hole
using the methids described in there made sites load at normal speeds again, i'll have to look into why my pi changed IPv6 adresses.
