Hi there,
when accessing some domains / subdomains I get:
"Access to the following site has been blocked:
cloud2.mailify.de
If you have an ongoing use for this website, please ask the owner of the Pi-hole in your network to have it whitelisted.
This page is blocked because it is explicitly contained within the following block list(s): "
There is no info on which list cloud2.mailify.de could be.
When whitelisting cloud2.mailify.de and mailify.de cloud2 is still be blocked.
When manually querying the lists "queryads.php" there are no results
question beside: Is wildcard whitel- and blockisting possible?
same with n1.nodenet.de or cdnjs.cloudflare.com (used for webfonts etcpp)
accessing cdnjs.cloudflare.com I get: "var x = "Pi-hole: A black hole for Internet advertisements.""
none of your domains are blocked for me. But maybe your blocklists are different.
You can easily check your blocked domains with TOOLS > QUERY ADLISTS and see which lists are blocking your domains!
After whitelisting, refreshing browser caches and maybe restarting RPi, it should work.
I did.. but 0 results..
these domains are mine. so I would really be surprised if they where blocked by some list.
Whats output for below 4 on Pi-hole ?
sudo grep 'mailify.de\|nodenet.de\|cloudflare.com' /etc/pihole/*list*
host cloud2.mailify.de localhost
host cloud2.mailify.de $(grep PIHOLE_DNS_1 /etc/pihole/setupVars.conf | awk -F = '{print $2}')
host cloud2.mailify.de $(grep PIHOLE_DNS_2 /etc/pihole/setupVars.conf | awk -F = '{print $2}')
If it's not on one of your blocklists, you may be running into cache issues.
Why Do We Need Cache?
Cache plays an important role with Pi-hole. This is part of the reason Pi-hole can make your network perform faster . Once a queried domain name has been cached, future replies for that same domain name will be much faster since Pi-hole already knows about it.
Problems When White Or Black Listing
However, you can run into issues if you decide to white or blacklist a domain that is already cached. For example, if you saw ads on a site and decided to blacklist wsp.mgid.com ,…
The pihole command lets you control, configure, and update your Pi-hole.
Autocomplete
Press tab after writing pihole to see the available options.
General Usage
Usage: pihole [options]
Example: 'pihole -w -h'
Add '-h' after specific commands for more information on usage
Whitelist/Blacklist Options:
-w, whitelist Whitelist domain(s)
-b, blacklist Blacklist domain(s)
-wild, wildcard Blacklist domain(s), and all its subdomains
Add '-h' for more info…
/etc/pihole/list.18.v.firebog.net.domains:cdnjs.cloudflare.com
/etc/pihole/list.preEventHorizon:cdnjs.cloudflare.com
/etc/pihole/whitelist.txt:mailify.de
/etc/pihole/whitelist.txt:cloud2.mailify.de
/etc/pihole/whitelist.txt:cloud.mailify.de
/etc/pihole/whitelist.txt:cdnjs.cloudflare.com
/etc/pihole/whitelist.txt:cloudflare.com
Using domain server:
Address: 127.0.0.1#53
Aliases:
cloud2.mailify.de has address 5.1.89.185
Address: 204.152.184.76#53
Aliases:
You mentioned that they were your domains, are they hosted on the same Pi-hole device or are they hosted on another platform?
they are.. oh **** I see...
I think I need to tidy up my domain ns-settings ^^ awkward
Thanks guys!!!
Sure, the block page is actually the 404 handler for lighttpd
so if you are hitting a domain that is hosted on the same device as the Pi-hole, you'll see the blockpage instead of a 404 error message, so that can confuse things when you are setting up your configurations.
