I've tried that before and i've done it yet againbut it unfortunately it does not help:
[✓] Restarting DNS service
*** Can't find meine.postbank.de: No answer
hmmm does your Pi-hole run? Try nslookup pi-hole.net and flurry.com
Which DNS sever do you have selected in Pi-hole?
What is the content of your /etc/resolv.conf?
same what chiliseek wrote
i changed to quad9 and the same problems
$ netstat -tulpen | grep :53
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 999 477060 -
tcp6 0 0 :::53 :::* LISTEN 999 477062 -
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 10420 -
udp 0 0 0.0.0.0:53 0.0.0.0:* 999 477059 -
udp6 0 0 :::5353 :::* 108 10421 -
udp6 0 0 :::53 :::* 999 477061 -
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 999 477060 3996/pihole-FTL
tcp6 0 0 :::53 :::* LISTEN 999 477062 3996/pihole-FTL
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 10420 275/avahi-daemon: r
udp 0 0 0.0.0.0:53 0.0.0.0:* 999 477059 3996/pihole-FTL
udp6 0 0 :::5353 :::* 108 10421 275/avahi-daemon: r
udp6 0 0 :::53 :::* 999 477061 3996/pihole-FTL
@anon55913113, thanks a lot for your support and time! How do i make a new official support request? Just open a new topic?
my new debug token is: zq28aoqitq
thanks again. I've now created a new topic for this issues: Pihole blocking whitelisted domain/none blocked domain
a strange thing. the url
https://www.postbank.de/privatkunden/pk_sicherheit_kartenlimit.html
is working. the url
not
This might be the solution: Postbank and Cloudflare have problems with each other.
thxs. i changed to opendns and all is working
