Weather, App Store and apple news will not load on my apple watch unless I turn off Wi-Fi on my iPhone
so I believe my pihole server is blocking a domain it needs, would anyone know what it is, I have tried looking in Query log and could not find anything blocked from my iPhone or Watch
The latter indicates the former is likely not the case.
the apple watch rarly queries directly though pihole itself, but though my iPhone over bluetooth then to Wi-Fi there both on the default group, I could try them on the allow all group to see if its the same
after restarting my watch and iPhone it works
so I think something is being blocked, but during the timeframe I am on weather or app store there are no blocked queries from either devices
that group works perfectly, and I no longer have the issue when using it, but I do still need my iPhone in the default group for blocking, but can not find the domains that its blocking
I don't seem to have the issue after restarting the devices, but maybe they cached with I was using allow all
then after restarting my phone again, I can't access weather or app store
Dec 30 18:46:19: query[HTTPS] p43-quota.icloud.com from 10.42.0.5
Dec 30 18:46:19: cached p43-quota.icloud.com is <CNAME>
Dec 30 18:46:19: forwarded p43-quota.icloud.com to 1.1.1.1
Dec 30 18:46:19: query[A] p43-quota.icloud.com from 10.42.0.5
Dec 30 18:46:19: reply p43-quota.icloud.com is <CNAME>
Dec 30 18:46:19: reply quota.fe.apple-dns.net is NODATA
Dec 30 18:46:19: reply quota.fe.apple-dns.net is 17.250.81.67
Dec 30 18:46:19: query[HTTPS] quota.fe.apple-dns.net from 10.42.0.5
Dec 30 18:46:19: forwarded quota.fe.apple-dns.net to 1.1.1.1
Your watch switches between these intelligently to choose the most power-efficient connection. Here’s how:
Your Apple Watch uses Bluetooth when your iPhone is near, which conserves power.
If Bluetooth isn’t available, your Apple Watch will try to use Wi-Fi. For example, if compatible Wi-Fi is available and your iPhone isn't in Bluetooth range, your Apple Watch uses Wi-Fi.
If Bluetooth and Wi-Fi aren't available, and you set up a cellular plan, cellular models of Apple Watch can connect to mobile networks.
