Details about my system:
This is my debug token
I just disabled logging today. This is the only change I've done to date.
Thank you for your help
The issue I am facing:
Disk space all used up and I don't know by what
this is the output from df -ah command
Filesystem Size Used Avail Use% Mounted on
/dev/loop0 20G 17G 2.1G 90% /
none 492K 4.0K 488K 1% /dev
proc 0 0 0 - /proc
proc 0 0 0 - /proc/sys/net
proc 0 0 0 - /proc/sysrq-trigger
sysfs 0 0 0 - /sys
sysfs 0 0 0 - /sys/devices/virtual/net
fusectl 0 0 0 - /sys/fs/fuse/connections
debugfs 0 0 0 - /sys/kernel/debug
securityfs 0 0 0 - /sys/kernel/security
pstore 0 0 0 - /sys/fs/pstore
mqueue 0 0 0 - /dev/mqueue
efivarfs 0 0 0 - /sys/firmware/efi/efivars
binfmt_misc 0 0 0 - /proc/sys/fs/binfmt_misc
proc 0 0 0 - /dev/.lxc/proc
sys - - - - /dev/.lxc/sys
none 0 0 0 - /sys/fs/cgroup
lxcfs 0 0 0 - /proc/cpuinfo
lxcfs 0 0 0 - /proc/diskstats
lxcfs 0 0 0 - /proc/loadavg
lxcfs 0 0 0 - /proc/meminfo
lxcfs 0 0 0 - /proc/stat
lxcfs 0 0 0 - /proc/swaps
lxcfs 0 0 0 - /proc/uptime
lxcfs 0 0 0 - /sys/devices/system/cpu/online
udev 7.8G 0 7.8G 0% /dev/full
udev 7.8G 0 7.8G 0% /dev/null
udev 7.8G 0 7.8G 0% /dev/random
udev 7.8G 0 7.8G 0% /dev/tty
udev 7.8G 0 7.8G 0% /dev/urandom
udev 7.8G 0 7.8G 0% /dev/zero
devpts 0 0 0 - /dev/pts
devpts 0 0 0 - /dev/ptmx
devpts 0 0 0 - /dev/console
devpts 0 0 0 - /dev/tty1
devpts 0 0 0 - /dev/tty2
none 492K 4.0K 488K 1% /proc/sys/kernel/random/boot_id
tmpfs 7.8G 764K 7.8G 1% /dev/shm
tmpfs 1.6G 100K 1.6G 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock```
