After upgrade to 6.0 I get "403 forbidden" on webinterface
Since I did upgrade to version 6.0 via "pihole -up" I get always "403 forbidden" on web interface.
In my bare metal installation I use nginx as webserver. In the error.log I found this:
directory index of "/var/www/html/admin/" is forbidden
What can I do?
Pi-hole seems to work properly, but web interface.
Thanks,
Schultze
So you Reverse Proxy from NginX to the Pi-Hole webGUI ?!
A lot has changed so you need to adjust your NginX "Virtual Host" configuration :wink:
(I only speak Apache httpd hence the Virtual Host mentioned but I am guessing you know what I mean...)
Are you accessing the admin URL with http: or https:? V6 seems to insist on the latter.
No, it doesn't.
You can use http without issues in v6.
If you can't access via http, please open a new topic with a debug log. We can help you find the issue.
Here it is:
https://tricorder.pi-hole.net/cmP8h8n7/
Not really. I use nginx as webserver. It provides more than PiHole-WebUI.
https
Please post nginx configuration. nginx runs as root, so a 403 is likely related to a config problem.
This was working before update:
Pihole
location /*.js {
            index pihole/index.js;
    location /admin {
            index index.php index.html index.htm;
            location ~ \.php$ {
                    include snippets/fastcgi-php.conf;
                    fastcgi_pass unix:/run/php/php-fpm.sock;
From similar posts here, try to add /api as a location. Pihole made some webserver changes with the update to v6.
I already tried:
Pihole
location /*.js {
    location /admin {
            location ~ \.php$ {
    location /api {
            location ~ \.php$ {
Nothing changed. Still 403 forbidden.
As mentioned in the Announcement for Introducing Pi-hole v6, Pi-hole v6's employment of an embedded webserver has eliminated the need for lighttpd as well as PHP, with the newly embedded webserver leveraging Lua for serving the UI.
Your debug log shows that you run nginx as webserver, with Pi-hole's embedded webserver being completely disabled:
    tcp:192.168.42.1:443 is in use by nginx
    tcp:0.0.0.0:80 is in use by nginx
    tcp:127.0.0.1:443 is in use by nginx
    tcp:[::]:80 is in use by nginx
   [webserver]
     port = "" ### CHANGED, default = "80o,443os,[::]:80o,[::]:443os"
If you want nginx to serve Pi-hole's web UI instead of Pi-hole's embedded webserver, you'd have to add at least Lua capabilities to nginx, and even with Lua support, nginx won't be able to retrieve data from pihole-FTL.
You should enable Pi-hole's embedded webserver on its own port, and perhaps optionally configure nginx as reverse proxy, redirecting HTTP requests to Pi-holes webserver.
To start Pi-hole's webserver on a different port, you'd need to configure webserver.port under All settings » Miscellaneous, or via CLI, e.g. to have it listen on 8081 (IPv4/IPv6 HTTP) and 8443 (IPv4/IPv6 HTTPS):
sudo pihole-FTL --config webserver.port "8081o,8443os,[::]:8081o,[::]:8443os"
All settings is available in Expert mode only.
EDIT:
Unrelated to your webserver issue, there are two other observations from your debug log you may want to address, one of them urgently.
a. consider to disable Pi-hole's embedded NTP service via All settings » Network Time Sync, as your debug log indicates there is already a running NTP service on your machine:
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
 count last timestamp       type    message                                                       blob1                 blob2
 1     2025-02-22 08:54:50  NTP     Cannot bind to IPv4 address 0.0.0.0:123 (Address in use), IP  Error                 server
                                     v4 NTP server not available
This isn't critical, as Pi-hole detects the other NTP service and won't enable its own.
b. Your router advertises its own IPv6 addresses as DNS server:
     Recursive DNS server 1/2: fd00::<redacted>15
     Recursive DNS server 2/2: 2a<redacted>15
This is critical: As your router is advertising its own IPv6 addresses, that would allow your clients to by-pass Pi-hole (which is completely independent of any of Pi-hole's versions).
As your debug log indicates you are using a Fritzbox router, you could consider to configure it to distribute Pi-hole's IPv4 for DNS exclusively, see Unresolved ipv6 adress in my top list - #4 by Bucking_Horn.
