After rebooting Ubuntu 18.04 Pi-hole doesn’t work until I run the command “pihole restartdns”
Every time I reboot pihole I have to do a "pihole restartdns" and everything then comes up and starts working.
I've searched here and askubuntu and nothing is working for me.
Tried this:
https://discourse.pi-hole.net/t/ubuntu-mint-after-rebooting-pi-hole-doesnt-work-until-i-run-the-command-pihole-restartdns/1645
Doesn't work for me.
Tried this:
https://askubuntu.com/questions/536787/dnsmasq-starting-before-eth0-is-ready-and-therefore-not-binding
Doesn't work for me because I don't have dnsmasq.service
I've searched for other ways to try and delay dnsmasq from starting but seem to be going round in circles.
So can anyone tell me how to fix this problem. I'm pretty sure if I can just delay the start of dns it will fix the problem.
thanks
After the reboot and before you run pihole restartdns, run
sudo systemctl status --full --no-pager pihole-FTL.service and post the output here.
? pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Sat 2019-06-29 03:02:05 AEST; 1min 17s ago
Process: 822 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jun 29 03:01:59 USPH1804 systemd[1]: Starting LSB: pihole-FTL daemon...
Jun 29 03:02:00 USPH1804 pihole-FTL[822]: Not running
Jun 29 03:02:02 USPH1804 su[1003]: Successful su for pihole by root
Jun 29 03:02:02 USPH1804 su[1003]: + ??? root:pihole
Jun 29 03:02:02 USPH1804 su[1003]: pam_unix(su:session): session opened for user pihole by (uid=0)
Jun 29 03:02:05 USPH1804 pihole-FTL[822]: FTL started!
Jun 29 03:02:05 USPH1804 systemd[1]: Started LSB: pihole-FTL daemon.
Output looks ok.
After the reboot
  • any errors or interesting messages in /var/log/pihole-FTL.log ?
  • run sudo netstat -tulpen | grep "pihole\|dhcp\|lighttpd" and post it here.
Only thing that looks sus to me is:
ERROR compiling regex on line 1: Invalid preceding regular expression (13)
And the outout from netstat before restarting DNS
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          21063      928/lighttpd
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      999        21580      1047/pihole-FTL
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21591      1047/pihole-FTL
tcp6       0      0 :::80                   :::*                    LISTEN      0          21064      928/lighttpd
tcp6       0      0 fe80::e852:c420:4de::53 :::*                    LISTEN      999        21912      1047/pihole-FTL
tcp6       0      0 ::1:53                  :::*                    LISTEN      999        21582      1047/pihole-FTL
tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21593      1047/pihole-FTL
udp        0      0 127.0.0.1:53            0.0.0.0:*                           999        21579      1047/pihole-FTL
udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21376      975/dhcpcd
udp6       0      0 fe80::e852:c420:4de::53 :::*                                999        21911      1047/pihole-FTL
udp6       0      0 ::1:53                  :::*                                999        21581      1047/pihole-FTL
And after restarting DNS
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      999        23766      1425/pihole-FTL
tcp        0      0 192.168.0.15:53         0.0.0.0:*               LISTEN      999        23764      1425/pihole-FTL
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        23784      1425/pihole-FTL
tcp6       0      0 ::1:53                  :::*                    LISTEN      999        23770      1425/pihole-FTL
tcp6       0      0 fe80::e852:c420:4de::53 :::*                    LISTEN      999        23768      1425/pihole-FTL
tcp6       0      0 ::1:4711                :::*                    LISTEN      999        23786      1425/pihole-FTL
udp        0      0 0.0.0.0:65358           0.0.0.0:*                           999        24138      1425/pihole-FTL
udp        0      0 127.0.0.1:53            0.0.0.0:*                           999        23765      1425/pihole-FTL
udp        0      0 192.168.0.15:53         0.0.0.0:*                           999        23763      1425/pihole-FTL
udp        0      0 0.0.0.0:7765            0.0.0.0:*                           999        24151      1425/pihole-FTL
udp        0      0 0.0.0.0:65125           0.0.0.0:*                           999        24135      1425/pihole-FTL
udp        0      0 0.0.0.0:24197           0.0.0.0:*                           999        24142      1425/pihole-FTL
udp6       0      0 ::1:53                  :::*                                999        23769      1425/pihole-FTL
udp6       0      0 fe80::e852:c420:4de::53 :::*                                999        23767      1425/pihole-FTL
Mod Edit: formatted output
Try editing these lines in /etc/init.d/pihole-FTL
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
and replace them with these lines:
# Required-Start:    $remote_fs $syslog $network
# Required-Stop:     $remote_fs $syslog $network
And then reboot your device.
For a (silly) temporary fix, you could add
@reboot sleep 1m && pihole restartdns
To your crontab.
Disclaimer: this is just to automate the restartdns on boot and will not fix the root of your problem.
If @Mcat12 method dont work, below Ubuntu user had something similar.
Solution in that thread is more like a patch and not really a fix.
If have similar issue, you need to figure out why the interface comes up late (dmesg etc).
And your netstat looks a bit fragmented.
Below how a clean netstat could look like:
pi@noads:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471[1-8] '
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      2957/pihole-FTL
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      2957/pihole-FTL
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      579/lighttpd
tcp6       0      0 :::53                   :::*                    LISTEN      2957/pihole-FTL
tcp6       0      0 ::1:4711                :::*                    LISTEN      2957/pihole-FTL
tcp6       0      0 :::80                   :::*                    LISTEN      579/lighttpd
udp        0      0 0.0.0.0:53              0.0.0.0:*                           2957/pihole-FTL
udp        0      0 0.0.0.0:67              0.0.0.0:*                           2957/pihole-FTL
udp6       0      0 :::53                   :::*                                2957/pihole-FTL
Check for alien config files not belonging to Pi-hole with below one:
sudo grep -v '^#\|^$' -R /etc/dnsmasq.* | sort
Didn't work
#!/bin/bash
### BEGIN INIT INFO
# Provides:          pihole-FTL
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: pihole-FTL daemon
# Description:       Enable service provided by pihole-FTL daemon
### END INIT INFO
sleep 30
FTLUSER=pihole
PIDFILE=/var/run/pihole-FTL.pid
That worked! Changed it to 20 seconds though
Note that this change will be overwritten by any future updates.
No worries, I'll keep an eye on it after updating. Thanks for your help!
One last thing, the output of
/etc/dnsmasq.conf:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.old:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.d/01-pihole.conf~:addn-hosts=/etc/pihole/black.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/black.list
/etc/dnsmasq.d/01-pihole.conf~:addn-hosts=/etc/pihole/gravity.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/gravity.list
/etc/dnsmasq.d/01-pihole.conf~:addn-hosts=/etc/pihole/local.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/local.list
/etc/dnsmasq.d/01-pihole.conf~:bogus-priv
/etc/dnsmasq.d/01-pihole.conf:bogus-priv
/etc/dnsmasq.d/01-pihole.conf~:cache-size=10000
/etc/dnsmasq.d/01-pihole.conf:cache-size=10000
/etc/dnsmasq.d/01-pihole.conf~:dhcp-ignore-names=tag:wpad-ignore
/etc/dnsmasq.d/01-pihole.conf:dhcp-ignore-names=tag:wpad-ignore
/etc/dnsmasq.d/01-pihole.conf~:dhcp-name-match=set:wpad-ignore,wpad
/etc/dnsmasq.d/01-pihole.conf:dhcp-name-match=set:wpad-ignore,wpad
/etc/dnsmasq.d/01-pihole.conf~:domain-needed
/etc/dnsmasq.d/01-pihole.conf:domain-needed
/etc/dnsmasq.d/01-pihole.conf:interface=enp0s4
/etc/dnsmasq.d/01-pihole.conf~:localise-queries
/etc/dnsmasq.d/01-pihole.conf:localise-queries
/etc/dnsmasq.d/01-pihole.conf~:local-ttl=2
/etc/dnsmasq.d/01-pihole.conf:local-ttl=2
/etc/dnsmasq.d/01-pihole.conf~:log-async
/etc/dnsmasq.d/01-pihole.conf:log-async
/etc/dnsmasq.d/01-pihole.conf~:log-facility=/var/log/pihole.log
/etc/dnsmasq.d/01-pihole.conf:log-facility=/var/log/pihole.log
/etc/dnsmasq.d/01-pihole.conf~:log-queries
/etc/dnsmasq.d/01-pihole.conf:log-queries
/etc/dnsmasq.d/01-pihole.conf~:no-resolv
/etc/dnsmasq.d/01-pihole.conf:no-resolv
/etc/dnsmasq.d/01-pihole.conf~:server=156.154.70.1#53
/etc/dnsmasq.d/01-pihole.conf:server=156.154.70.1#53
/etc/dnsmasq.d/01-pihole.conf~:server=8.8.8.8#53
/etc/dnsmasq.d/01-pihole.conf:server=8.8.8.8#53
/etc/dnsmasq.d-available/lxd:bind-interfaces
/etc/dnsmasq.d-available/lxd:except-interface=lxdbr0
/etc/dnsmasq.d/lxd:bind-interfaces
/etc/dnsmasq.d/lxd:except-interface=lxdbr0
Id there anything there that shouldn't be?
And thanks for all your help guys it was driving me crazy! :upside_down_face:
Yes.
The config file /etc/dnsmasq.d/lxd is not a Pi-hole one.
Try move it out of that folder to your home folder (for backup):
sudo mv /etc/dnsmasq.d/lxd ~
Restart pihole-FTL:
sudo service pihole-FTL restart
And check again:
Yeah dude I was logged into the wrong linux box when I posted that, I've now edited it sorry about that :slight_smile:
netstat clean now ?
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      882/lighttpd
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      1973/pihole-FTL
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      1973/pihole-FTL
tcp6       0      0 :::80                   :::*                    LISTEN      882/lighttpd
tcp6       0      0 :::53                   :::*                    LISTEN      1973/pihole-FTL
tcp6       0      0 ::1:4711                :::*                    LISTEN      1973/pihole-FTL
udp        0      0 0.0.0.0:53              0.0.0.0:*                           1973/pihole-FTL
udp6       0      0 :::53                   :::*                                1973/pihole-FTL
Looks better to me
It sure does :wink:
Thanks again dude, ya worth more money! :money_mouth_face:
I have one further question for fixing it in upcoming releases if you don't mind: When you again remove the sleep 20 in your init script (so that the command fails), what is the output in /var/log/pihole.log?
No dramas
I removed the sleep 20 from /etc/init.d/pihole-FTL and rebooted
System came back up with everything working. Strange so I rebooted again same thing, everythings working.
Changed this
Back to this
And it still came up working. So I then moved lxd back to /etc/dnsmasq.d and rebooted, it failed! So that was the problem all along.
I did a clean install of Ubuntu 18.04 Server as a VM and setup PiHole in that, I don't remember doing anything with DNS during that install so it might be a default thing I'm not sure.
Anyway, its now working and I now know it was this lxd symlink that was causing the problem all along and nothing to do with PiHole.
And if you hadn't asked me for the output of /var/log/pihole.log and I'd looked into this more we might never have gotten to the true cause of the problem.
I take it you don't need to see the output of /var/log/pihole.log anymore? :upside_down_face:
