Adding small section on DNS rebind protection in Fritz!Box docs
I recently had issues setting up Pi-hole with a Fritz!Box router.
The docs on this are really good but didn’t mention anything about DNS rebind protection which was enabled by default on my router (FRITZ!Box 4050, FRITZ!OS: 8.02).
This setting caused heavy delays when resolving domains and it took some time until I was able to find and fix it. Since there are specific docs on this brand of router I was thinking I should add a section in the docs so others might have an easier time. I’m not an expert but with some feedback I should be able to do this.
Roughly I would add:
  • a sub-header “Add Pi-hole as exception for DNS rebind protection“ in the “Distribute Pi-hole as DNS server via DHCP“ section in the docs
  • explanation that this might not be applicable for all router types and OS versions
    (maybe people can direct me to a list of versions that have this setting on by default - but I think it’s unlikely this information exists)
  • instructions with a screenshot on how to add an exception for Pi-hole
Is this the right way to go about this and should my next step be to open a PR in the Pi-hole/docs repo for this?
Additional resources
Similar issue (fritzbox is also mentioned in this thread):
Relevant FAQ topic:
FritzBox routers do enable DNS rebind protection by default. It can't be turned off entirely, but they allow you to configure exemptions.
Your contribution would be most welcome.
Just note:
That wouldn't be the correct section.
Your router's DNS rebind protection would kick in if your router receives a private IP address as DNS reply from its upstream, i.e. it could interfere with Pi-hole serving local names if you configured your router to use Pi-hole as upstream DNS server for your Fritz!Box.
When considering to contribute via GitHub, note that clicking the pencil on the top right of a doc page will take you to the respective GitHub source.
Yes thank you for the correction - it should be under Pi-hole as DNS server via DHCP.
I tried both and misremembered which one I landed on.
If I understand you correctly you’d say it’s the case for all/most FritzBox routers and it’s not necessary to specify that it might not be applicable for certain versions?
Happy to do the change and close this topic after I got this information!
