Dear forum,
My YI cam uses 192.168.1.1 instead of his static ip 192.168.1.7
So it is more difficult block or analysis
Do you know why ?
Is that screen shot from the pihole? If so it would suggest that your routers WAN may be setup to use the pihole as opposed to the LAN / DHCP. You will want to post a debug log by going to the webgui for pihole and then tools>generate debug log and then post the token at the bottom of the report so a dev can review.
