Wireguard VPN blocks admin dashboard
If you are Experiencing issues with a Pi-hole install that has non-standard elements (e.g you are using nginx instead of lighttpd, or there is some other aspect of your install that is customized) - please use the Community Help category.
Hardware: Raspberry pi 3 running rpiOS with Pihole 5.1.1
I have pivpn with wireguard and Pihole installed on my pi and I chose to integrate pihole with wireguard. Now if I connect to 192.168.0.36/admin I get a
Your Internet access is blocked. Firewall or antivirus software may have blocked the connection.
I know the site works cause with OpenVPN or no VPN it works just fine.
https://tricorder.pi-hole.net/6nb8xqwtbz
