Wired device not using Pi-hole
I am too Facing this same issue
I use Wireguard + pi-hole
on wireless device it working well
in wired devices it does not block the ads
Hi i try this on My Ubuntu system 18.04 LTS - wired connection
nslookup pi.hole
Server:		1.1.1.1
Address:	1.1.1.1#53
** server can't find pi.hole: NXDOMAIN
Run with pi-Hole IP
Server:	10.66.66.1
Address:	10.66.66.1#53
Address: 10.66.66.1
Address: <IP V6 of the server>
This client is not using Pi-hole for DNS. Either it is manually assigned to Cloudflare or it is getting this assignment from the router.
added the 1.1.1.1 DNS on My Router
wireless connection are work well
having this issue on wired connection
Remove the 1.1.1.1 DNS from the router.
replace with PI-hole DNS?
but i don't want to use it globally
In this case, you will need to manually map clients to use Pi-hole, or use the group management feature of Pi-hole to bypass filtering on selected devices.
any other solution to fix this?
I use wireguard
wg0 method
so PI-hole connect via wireguard VPN
Finally, I Fixed this issue
By disabling Auto Dns Option
Stop Network Manager from adding DNS Servers Dynamically
nano /etc/NetworkManager/NetworkManager.conf
[main]
dns=none
  • restart the Network Manager
systemctl restart NetworkManager.service
  • Update the Pi-hole DNS Server on /etc/resolv.conf
nano /etc/resolv.conf
nameserver <Pi-hole DNS>
nameserver 1.1.1.1
Now it's Blocking the Ad's
Wireguard + Pi-hole working well
