Why is there a NTP running in docker container with V6?
I found by docker logs -t pihole that there's a "NTP server listening on localhost" within the docker container. Why? There should be no reason for this or I don't know the reason…
There's also a warning that doesn't make sense within a docker container (when there's already some "time"-demon/service running on linux hosting this container)
WARNING: Insufficient permissions to set system time (CAP_SYS_TIME required), NTP client not available
I am guessing because of a lot of demand from the community ?! :slight_smile:
I was surprised too, but don't see it as an issue!
Pi-hole is typically used installed directly on the device. Running it inside a docker container is only encapsulating the same system in a minimal container environment. So why is it running in the container? Because nobody disabled it and I also don't see it as an issue.
Background for this feature is that it has been requested and there is an RFC concerning DHCP that suggests you may offer NTP together with DHCP as a local service. The NTP server is then actively announced by the DHCP server to its clients. As Pi-hole can act as DHCP server, extending it to also give NTP service out-of-the-box seems a logic extension.
If you open the port into your container, it'd work.
Obviously, your NTP server's time should be as accurate as possible and - when you see the warning about CAP_SYS_TIME not being available, your Pi-hole complains that it could not set/stabilize your system time. You can either grant the capability or disable the feature.
I still think this all makes perfect sense.
Ok, I understood and disabled NTPD in my docker-setup by active = false in ntp.ipv4 INI section :+1:
I see this differently.
In the containerized setup the container should not be responsible for setting/stabilizing host system time, it should rather accept the system time that is provided by the host.
Thus I'd prefer having ntp.ipv4.active=false by default in the image or at least some parameter available that I can pass to docker/podman to disable port "123/udp" exposing.
Is there any FTLCONF option that I can use or the only way is via :
pihole-FTL --config ntp.ipv4.active false
pihole-FTL --config ntp.ipv6.active false
pihole-FTL --config ntp.sync.active false
