Whitelist for pi-hole
Dear all,
I would add a whitelist for pi-hole, where could I find the list?
It’s important for pi-hole project because it’s not necessary block add or frame in many websites, for example institutional, bank, museums, government, etc… websites.
I search an Italian website whitelist for pi-hole.
Thanks for your feedback.
Pi-hole will block domains that are included on the adlists that you tell it to use, in Adlists in the side menu. Try to use adlists which do not include the domains that you wish to use. This way, they will not be blocked.
If you have any domains that are blocked you can override the blocking by using the whitelist which is found in Domains in the side menu. Copy and paste the domains that you would like to whitelist into the Domain box and click the button Add to Whitelist. You can copy and paste a lot of domains all at once, the page understands.
If something is not working because a domain is blocked, you can see the blocked domain the Query Log in the side menu. From there you can click the Whitelist button to add that domain to the whitelist.
