Title says it all, running in docker was trying to do a for loop to get black/whitelists out of a text file
for i in $(cat list); do pihole -b "$i"; done
pihole6:/# pihole -b example.com
grep: unrecognized option: P
BusyBox v1.36.1 (2023-07-27 17:12:24 UTC) multi-call binary.
Usage: grep [-HhnlLoqvsrRiwFE] [-m N] [-A|B|C N] { PATTERN | -e PATTERN... | -f FILE... } [FILE]...
Search for PATTERN in FILEs (or stdin)
-H Add 'filename:' prefix
-h Do not add 'filename:' prefix
-n Add 'line_no:' prefix
-l Show only names of files that match
-L Show only names of files that don't match
-c Show only count of matching lines
-o Show only the matching part of line
-q Quiet. Return 0 if PATTERN is found, 1 otherwise
-v Select non-matching lines
-s Suppress open and read errors
-r Recurse
-R Recurse and dereference symlinks
-i Ignore case
-w Match whole words only
-x Match whole lines only
-F PATTERN is a literal (not regexp)
-E PATTERN is an extended regexp
-m N Match up to N times per file
-A N Print N lines of trailing context
-B N Print N lines of leading context
-C N Same as '-A N -B N'
-e PTRN Pattern to match
-f FILE Read pattern from file
-r Recurse
-i Ignore case
[✗] example.com is not a valid argument or domain name!
Thanks for bringing to to our attention, we have a PR aimed to resolve this by replacing pihole -q by a more modern variant, but it is still awaiting a certain decision, trying to get this rolling again.
This is an slightly different issue here: the v6 Docker image is alpine based which uses busybox as a multi-command binary. And the build-in grep does not offer the -P option.
We could add grep but this still does not work (notice: no issues running on bare metal)
014b4162b86:/# apk add grep
fetch https://dl-cdn.alpinelinux.org/alpine/v3.18/main/x86_64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.18/community/x86_64/APKINDEX.tar.gz
(1/1) Installing grep (3.10-r1)
Executing busybox-1.36.1-r2.trigger
OK: 51 MiB in 73 packages
a014b4162b86:/# pihole -b example.com
vs
nanopi@nanopi:~$ pihole -b example.com
[i] Adding example.com to the blacklist...
[✓] Reloading DNS lists
The proper fix is using the PR listed above, which implements some bash functions to interact with the API, and re-implement pihole -b/-w on top of that.
can this be done via the api? or do you guys know a "high speed" way to add it to the database directly for the time being. I have a big-ol-list.
edit:
found a loophole using the api
for i in $(cat whitelist); do curl http(s)://piholedomain/api/domains/allow/exact -H "Content-Type: appication/json" -d "{ "domain": "$i" }" -X POST ; sleep 1 ; done
