I added pinchofyum.com to the Pi Hole whitelist. I expect to navigate to the site and then be able to view the site like any other unblocked site.
Operating System (Family and Version) : Raspberry Pi OS Trixie, Pi Hole 6.5 (FTL 6.8)
Hardware: Raspberry Pi 4
I'm trying to access a particular site: pinchofyum.com. I whitelisted the domain specifically. I'm new to Pi Hole and networking, so my language might be off when I say "domain". When I navigate to the site, it starts to load and then a window opens saying "Please allow ads on this site. Click OK to learn more" and then the site stops loading. Then a new site site loads: reports.error-report.com with a message that says "unable to connect".
The website is correctly loaded, but the page also tries to load ads from a different domain.
Pi-hole blocks the ads, then a script on the page identifies that ads are not load and shows the message.
TIP : Some of those are very easily filtered out by uBlock Origin in LibreWolf or Firefox so you might want to try that option first before you start Whitelisting domains that serve ads
Thanks for the reply. I suppose I have to whitelist some of the ad domains? Is there a way to determine which ones? It's not clear to me what's a domain for ads and what's might be a domain serving something else and whether or not I want to add it.
As it is, the site doesn't work at all after a minute of it trying to load ads. It loads some other site like error-report.com and I never see any of the content.
Another practical way to see which domains are involved: open your browser's developer tools (F12), go to the Network tab and reload pinchofyum.com. Requests that fail or show as blocked are the ones Pi-hole is dropping. You can also check Pi-hole's Query Log right after the page loads. Then allow only the specific domain the ad-detection script needs instead of whitelisting everything, and re-test.
To add some more information for anyone stumbling into this
If you see "error-report.com"
This is Ad-Shield Anti Ad Blocker & Ad Recovery.
A very aggressive anti ad blocker.
Generally, for Ad-Shield, unblocking html-load.com gets things working.
But of course, you will see ads load in from said domain
That is their main domain to "recover" ads from.
But, they also make use of a wide variety of domains, most sketchy sounding.
Unfortunately, DNS Blocking alone cannot tackle Ad-Shield
