While executing: attempt to write a readonly database & Teleport Import not working
Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Done
Problem with Beta 5.0:
Adding a Domain in Webinterface white/black dont work.
Error, something went wrong!
via SSH pihole -w domain its working
And Teleport Import is not Working. Just showing imported 0 on all Points.
Tools > Generate Debug Log
Token
js22yiwr9n
Can confirm thats a Beta 5 Failure. Rolled back to 4.4 and that works flawless.
Add Info:
System is DietPi Buster
Pi-hole V5 beta uses a new gravity database that is not present in V4.x. Let's looks at the permissions of the database files in /etc/pihole. What is the output of the following command from the Pi terminal
ls -lha /etc/pihole/*.db
-rw-rw-r-- 1 pihole pihole 294M Mär 2 12:15 /etc/pihole/gravity.db
-rw-r--r-- 1 pihole pihole 2.3M Mär 2 12:08 /etc/pihole/macvendor.db
-rw-r--r-- 1 pihole pihole 196K Mär 2 12:08 /etc/pihole/pihole-FTL.db
Also a Fresh Install wont Work.
It seems i have found the Problem.
Install Pi-Hole via DietPi Launcher = Problem
Install Pi-Hole via SSH Command = It seem working
Adding, Removing etc.. works now under Beta 5.0 and unbound.
Please let DietPi know that. We'd like to have their install method work as well as ours.
Done: https://dietpi.com/phpbb/viewtopic.php?f=11&t=7346
Could it be same issue as this ??
