The expected behaviour is that when my router’s DNS is set to the IP address of the Pihole container that the host won’t lose internet connection
Operating System: UGOS
Hardware: UGREEN DXP4800 Plus NAS
Docker compose file
# More info at https://github.com/pi-hole/docker-pi-hole/ and https://docs.pi-hole.net/ services: pihole: container_name: pihole image: pihole/pihole:latest network_mode: host # ports: Uncomment ports if using network_mode: bridge # DNS Ports # - "54:53/tcp" # - "54:53/udp" # Default HTTP Port # - "8808:80/tcp" # Default HTTPs Port. FTL will generate a self-signed certificate # - "4443:443/tcp" # Uncomment the line below if you are using Pi-hole as your DHCP server with network_mode: bridge #- "67:67/udp" # Uncomment the line below if you are using Pi-hole as your NTP server #- "123:123/udp" environment: # Set the WebUI ports when using network_mode: host FTLCONF_webserver_port: '8808,4443' # Set the appropriate timezone for your location (https://en.wikipedia.org/wiki/List_of_tz_database_time_zones), e.g: TZ: 'America/Toronto' # Set a password to access the web interface. Not setting one will result in a random password being assigned FTLCONF_webserver_api_password: 'yORQHkNTk&77rukfLcf' # If using Docker's default `bridge` network setting the dns listening mode should be set to 'all' # FTLCONF_dns_listeningMode: 'all' # Upstream DNS servers for Pi-hole to forward queries to when a domain isn't found on it's blocklists, separated by semicolon FTLCONF_dns_upstreams: 1.1.1.1;1.0.0.1;8.8.8.8;8.8.4.4 # Volumes store your data between container upgrades volumes: # For persisting Pi-hole's databases and common configuration file - './etc-pihole:/etc/pihole' # Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you're upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: 'true' #- './etc-dnsmasq.d:/etc/dnsmasq.d' cap_add: # See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities # Required if you are using Pi-hole as your DHCP server, else not needed - NET_ADMIN # Required if you are using Pi-hole as your NTP client to be able to set the host's system time - SYS_TIME # Optional, if Pi-hole should get some more processing time - SYS_NICE restart: unless-stopped -
Docker engine version: 26.1.0
When I test the Pihole by just manually setting something like my phone's DNS server to the Pihole IP (which is also the UGREEN NAS's IP due to being in host mode) it seems to work fine. However, as soon as I set my router (in this case an ISP modem) to use the Pihole's IP (again, the UGREEN NAS IP due to being in host mode) the NAS itself loses it's internet connection. It's still reachable over the LAN though. Also presumbaly due to the NAS losing it's internet connection the same test phone also loses it's ability to load anything on the internet.
