What order are DNS rules executed in?
I have looked about quite a bit and I cannot find any information on this. Specifically...
  • What order are allow/blocking rules executed in?
  • Does Pi-Hole stop at the first 'hit' (matching rule) or is it the last 'hit' that takes affect?
  • Are the installed domain lists checked first followed by the ad-hoc 'domain' entries? Or the other way round? Or are they actually all fundamentally the same list
  • Does the order of the rules in the 'domain' list matter?
  • Are regex rules treated the same as absolute rules for the purposes of ordering?
  • How does grouping effect things?
So, if I have a 'blocking' rule somewhere and an 'allow' rule somewhere else, which one will Pi-Hole settle on using? And does it matter where my two rules are defined?
Allow rules always take precedence over block rules.
The order is explained here: Domain Database - Pi-hole documentation
  • Allowed exact domains
  • Allowed lists
  • Allowed Regex
  • Blocked exact domains
  • Blocked lists
  • Blocked Regex
Pi-hole stops at the first match. If a domain is allowed, there is no need to keep searching. Also, if it is blocked by an "exact domain entry", there is no need to check regex rules.
No.
It doesn't affect blocking priorities as such.
The purpose of Pi-hole's Group Management is to allow client specific filtering, e.g. by having specific clients assigned to a group that is assigned a more restrictive set of blocklists.
Thank you very much for the clarification - much appreciated. Though I do feel a tad embarrassed at not finding it in the docs - my apologies for being blind/stupid
