My Pi Hole has only been running for about 24 hours or less and there are close to 900,000 hits to this "domain."
I tried searching for this but was unable to find anything exactly like this.
TIA
TIA
This is a DNS Discovery Service request. Frequently associated with the Apple Bonjour protocol.
If you have conditional forwarding enabled in Pi-hole, this can lead to circular DNS traffic and high query volumes.
Please generate a debug log, upload it when prompted and post the token here.
I didn't turn that on unless it is usually on.
Here is the debug log you requested.
https://tricorder.pi-hole.net/zhq8dxtt64
Thanks.
You do have conditional forwarding enabled:
REV_SERVER=true
REV_SERVER_CIDR=192.168.86.0/24
REV_SERVER_TARGET=192.168.86.1
REV_SERVER_DOMAIN=
This is the result - request from the router sent back to the router to resolve.
Oct 11 00:00:08 dnsmasq[1467]: query[PTR] lb._dns-sd._udp.0.86.168.192.in-addr.arpa from 192.168.86.1
Oct 11 00:00:08 dnsmasq[1467]: forwarded lb._dns-sd._udp.0.86.168.192.in-addr.arpa to 192.168.86.1
The conditional forwarding setting is in the admin GUI > settings > DNS. Disable this and see if the volume of queries drops.
