What is the use of /etc/.pihole/.git/?
The folder is touched every few minuted.
It is the Git folder for the core repo, which holds metadata about the repository. It is probably updated when Pi-hole checks the version periodically.
There is a cron script installed by Pi-Hole to check the local version every 10 minutes.
In /etc/cron.d/pihole
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
