The WebUI should save changes made there and it should show the correct status of the Pi-Hole
The status is unkown in the WebUI and any changes made won't take. Whitelist entries get the message: "Failure! Something went wrong, see output below: ". But there is no below...
zo11a86m0s
In the debug log I can see an issue with lighttpd:
[\u2717] Block page X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 403 Forbidden
Content-Type: text/html
Content-Length: 345
Date: Wed, 27 Feb 2019 19:51:27 GMT
Server: lighttpd/1.4.45
[\u2717] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Set-Cookie: PHPSESSID=ccqnhpj0gdp9bkqlcl1ds01ia7; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
This is a fresh install of Dietpi and Pi-Hole on a Tinkerboard. I had the same issue with the first install, but a different error in the debug log. Because I had tried to run a couple of stuff to find out what is possible and/or usefull for me, I opted for a fresh install. But here I am again with the same problem.
So far there is only Pi-Hole and AssetUPnP running on the system apart from the basics like ProFTP, OpenSSH and so on. No Samba or Apache or anything.
And please be patient with me, as I know my way around Windows systems, but am a beginner on anything that has to do with Linux in any form.
Thanks in advance!
Malte
