Websites from blocklist aren't being blocked
I have a couple of websites that I want to have blocked from certain devices. I had the clients in groups, and then the groups assigned to domains. At one point the blocking was working, but when I went to add a new site today I noticed none of the blocking was working. The client I am testing from does only show 1 dns server, and I have flushed the dns cache (more than once), as well as restarted Pihole.
I am sure this is something small and stupid that I missed, but I would appreciate any assistance you can give me.
Sites are not being blocked as they previously were on target machine.
Your debug token is: https://tricorder.pi-hole.net/le3431rcoc
Which set of domain blocks are you referring to, and on which of your devices?
   id    type  enabled  group_ids     domain        date_added           date_modified        comment
   3      1          1  1             heroes-wb.nextersglobal.com        2021-04-13 01:32:11  2021-04-13 01:32:21
   4        3        1  2             (\.|^)googlevideo\.com$        2021-05-19 22:36:59  2021-05-19 22:37:19  Youtube
   5        3        1  2             .*youtu\.?be.*        2021-05-19 22:37:14  2021-05-19 22:37:23  Youtube
   6        3        1  1             (\.|^)urbandictionary\.com/$        2021-06-11 15:02:46  2021-06-11 15:18:19
Also, for your iPhone, you have not entered the IP of the device, but have entered a local domain name for the device.
I just checked the youtube blocks, and they are working. The other two are not though (urbandictionary and nexterglobal), when accessed via the laptop. I also tried to access urbandictionary via the iphone and it did not block it there.
So domain 3 and 6 aren't working on either device. Domains 4 and 5 are working on the iPhone.
The regex (\.|^)urbandictionary\.com/$ does not pass a syntax check at https://regex101.com.
If you enter urbandictionary.com in Pi-hole as a wildcard domain, Pi-hole produces this regex which is valid:
(\.|^)urbandictionary\.com$
From the terminal or command prompt on the laptop, what are the outputs of the following commands:
nslookup pi.hole
nslookup heroes-wb.nextersglobal.com
nslookup flurry.com 192.168.13.2
okay that fixed the Urbandictionary. I had just copy/pasted the url in there and forgot to remove the trailing / before saving. As for the other question the results are below. I think I may have answered my own question though. the heroes-wb and hero-wars.com are essentially the same site (I think the nextersglobal one is where the actual game file is served from). Pi-hole can't block IP's though correct, so I would need to add a second entry to block hero-wars.com?
C:\>nslookup pi.hole
Server:  pihole
Address:  192.168.13.2
C:\>nslookup heroes-wb.nextersglobal.com
Server:  pihole
Addresses:  ::
          0.0.0.0
C:\>nslookup hero-wars.com
Server:  pihole
Non-authoritative answer:
Address:  18.200.3.232
C:\>nslookup flurry.com 192.168.13.2
Server:  pihole
Addresses:  98.136.103.23
          74.6.136.150
          212.82.100.150
