My own website (same server with pi-hole) shouldn't be blocked
Actually it is. Whitelisting the domain doesn't help
Update: after some research I think the issue is in conflict of pi-hole and my current webserver (apache).
Tried to apply found fixes, but it didn't worked for me. Please help.
Broken link sample: http://bebinka.com/nooks-and-crannies/
I tried to uninstall the pi-hole correctly, this renders all the previously blocked folders as 404..
How to fix..? It's a basic WP installation on Apache and Ubuntu.
Guys, it seems to me I dig down to the root of my issue – pi-hole replaced the lighttpd.conf, that's why all the sub-dirs of my website except the / are returning 404 error.
How to fix this?
cat /etc/lighttpd/lighttpd.conf
# Lighttpd config for Pi-hole
# FILE AUTOMATICALLY OVERWRITTEN BY PI-HOLE INSTALL/UPDATE PROCEDURE. #
# CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE: #
# /etc/lighttpd/external.conf #
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
# Prevent Lighttpd from enabling Let's Encrypt SSL for every blocked domain
#include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"\n' 2>/dev/null"
# If the URL starts with /admin, it is the Web interface
$HTTP["url"] =~ "^/admin/" {
# Create a response header for debugging using curl -I
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
# Allow Block Page access to local fonts
# Block . files from being served, such as .git, .github, .gitignore
url.access-deny = ("")
# Add user chosen options held in external file
