Webserver - tls.pem suddenly not working ( still valid )
Hello, I use pihole installed with the default installation script on a raspberry pi.
This setup worked for almost a year now. Today I noticed that I cannot access the webserver which was working fine. I use a self signed SSL cert which is still valid for a couple of years.
I have not touched my certs in any way so this could be related to the pihole update I made a couple days back.
Checking the webserver log:
[2026-03-06 11:38:20.912 CET 620] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os" [2026-03-06 11:38:20.926 CET 620] Error initializing SSL context
When I try to verify my TLS cert:
$ sudo pihole-FTL –read-x509
Reading certificate from /etc/pihole/tls.pem ...
No key found
Cannot parse certificate: Error code -15104
My TLS File:
Bag Attributes
friendlyName: piholero
localKeyID: 31 01 92 8E 33 CF 96 DD 7D 50 DD AE CA F1 E9 95 B0 D6 9F 9A
subject=C=DE, ST=BA, L=WUE, O=myorg, emailAddress=orgmail.com, CN=piholero
issuer=C=DE, ST=BA, L=WUE, O=myorg, emailAddress=orgmail.com, CN=intermediate-Opnsense
-----BEGIN CERTIFICATE-----
MIIHizCCBuygAwIBAgIBBTAKBggqhkjOPQQDBDCBijELMAkGA1UEBhMCREUxCzAJ
0/EEAXBnbcs7sB5mcxuZ2heUSh7FUMmWSDgk20BDvBpwatFNy8fjUbCtVLRLpdZQ
/E754JAzntMFZkfebSxk
-----END CERTIFICATE-----
Bag Attributes
Key Attributes:
-----BEGIN PRIVATE KEY-----
MIISQgIBADANBgkqhkiG9w0BAQEFAASCEiwwghIoAgEAAoIEAQCRBnz1diFKKjU+
dcE3wNB7Nr1u4lmzXNBZxNhDRZhkbw==
-----END PRIVATE KEY-----
checking the validity:
    Validity
        Not Before: Apr  9 11:21:51 2025 GMT
        Not After : Aug 24 11:21:51 2052 GMT
Token
Problem solved.
Created a new cert. Same format, same permissions. Now it’s working. Dont know what happened to the old cert file. Everything was still valid and worked without issues for months.
Do you actually manually create it or did you just delete it and let Pi-Hole create a new one ?
You see… there is this new rule that’s going to hit us all in the future : TLS Certificate Lifetimes Will Officially Reduce to 47 Days | DigiCert
I don’t know how the Pi-Hole Team is going to do this in the future, but when you create a certificate manually it’s something you should be aware of :slight_smile:
