webserver interface not working
I have just installed pi-hole with the standard docker image. The web interface was working perfectly, then now it does not load at all. Restarting containers does not help. What can I do to solve this?
Please provide a debug token.
Debug token: https://tricorder.pi-hole.net/Jm0OudzE/
Webserver is working now, it started working again without doing anything :-S
but I suppose it will eventually do same again.
Maybe this debug log does not help, I will repeat it as soon as it stops working.
As you suspect, your current debug log doesn't show any web server issues. It only shows you were previously using debug.webserver=true, but now this option is disabled.
I hope you don't need it, but if it happens again, generate a debug log while the issue is happening.
