Webbrowser/DNS resolution hangs
Hi!
Unfortuantely I suffer from the same problem since 10 years. It's always the same story: I grab a Raspberry, install Pi-hole, all works perfectly for a few days and then suddenly my webbrowser starts to hang, the DNS resolution simply isn't performant any more. Even "ping ..." in Windows would hang. Then I need to remove Pi-hole from my setup.
Now I tried it again a few days ago. After years, still the same.
I absolutely have no idea what that is. As upstream I use Google:
I checked the live query log and the queries do not show any delay, which is really strange.
Is it always the same one ?
A Raspberry Pi can have hardware issues too! :wink:
Ping to IP Address or Domain ?
What happens when you ping the IP Address of the Raspberry Pi on that moment ?
Without a debug log for the devs to review, you're shooting in the dark.
sudo pihole -d
Thanks for your time!
So far it turns out that likely I was just stupid. It's DNS, it's always DNS, it was always DNS—but in that case the DNS from my VPN. The OS used these servers without me knowing.
So I commented out all DNS lines for my configured Wireguard DNS servers and it seems it works now.
TIP : In general every OS gives the VPN DNS Servers complete priority once you are connected via the VPN unless you have configured it in such a way that it does not!
