instead of lighttpd
Able to browse to the admin site
I updated my pihole this morning using the usual pi -up command, all seemed well afterwards. This evening I can't get into the web ui (gives a connection refused error)
If I ssh into the pi itself wget https://localhost/admin works. If I do wget https:///admin it works
it's correctly serving dns inquires
F1atMvBl/
