This is a workaround for those who have a few clients and that they wish to see the DATA on.
- The line numbers referenced are for Pi-hole: v3.2.1, AdminLTE: v3.2.1, FTL: v2.13
Also seen in this thread (locked). And DEV team is aware of issue.
Clients (over time) graph tooltip out of sight
Web UI Dashboard: To see all client DATA in overlay/tooltip in 'Clients (over time)' chart
When a few clients are serviced, DATA in overlay/tooltip is cut off.
This seems to be a limitation of the feature.
N/A
Running Pi-hole (v3.2.1) on Centos 7
DCHP: ON (approx 16 clients)
Seen on Firefox 57 and Internet Explorer 11 both windowed and maximized.
Issue:
On the 'Dashboard', the 'Clients (over time)' overlay does not show completely. See image.
This occurs whether windowed or maximized, with slight differences between the two.
I'm guessing the overlay is not able to show all clients (16) because the overlay window is larger than the chart veiwport (canvas) so it gets pushed out of view.
Workaround:
In /var/www/html/admin/index.php line 117.
<canvas id="clientsChart" width="800" height="140"></canvas>
If I change the canvas height to 400, that helps with showing all clients in overlay. See image.
I would say if you have a few clients and wish to see this DATA, then increasing the canvas height would be a solution. If you need to change 'Queries over last 24 hours' line 92 is for that fix.
NOTE: If you do 'pihole up' or 'pihole -r' any changes made with be lost.
Thanks for listening.
