Web interface with password
I installed Pi-hole 6 on a Thin Client (Debian 11). The software works but the GUI is accessible without a password. I tried to change the password via SSH with the command "pihole setpassword NEWPASSWORD". The shell tells me that the password has changed but I can still access the web interface without logging in.
This command can fail if your password uses some special characters.
Try using single quotes around your password:
pihole setpassword 'NEWPASSWORD'
Does it fix the password?
If not, check if the command returns any error messages and please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
