My pi’s ip address loads the web interface
I get a blank screen
tricorder.pi-hole.net/osyx8ma960
Your debug log shows that lighttpd (the admin GUI web server) is not running. Since there is no lighttpd log, we can't look there for errors:
[✗] lighttpd daemon is inactive
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
/var/log/lighttpd does not exist.
Let's take a look at other records and see what's running on the ports used by Pi-Hole. What is the output of the following commands from the Pi terminal:
sudo systemctl status --full --no-pager lighttpd
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
Also, quick question. Does pi-hole affect VNC server from real VNC?
No.
For the lighttpd problem, run pihole -r
, select reconfigure, and when prompted install the web server.
This will recreate the repository:
cd /
sudo rm -rf /etc/.pihole
sudo git clone https://github.com/pi-hole/pi-hole /etc/.pihole
But when I type my pi’s is address it still shows a blank screen.
The next step is to repeat the reconfigure and see if the error has cleared and if the reconfigure will complete.
Just realized the whole time I went to 192.168.0.32, not 192.168.0.32/admin. So sorry.
Please generate a new debug log and post the token here.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[✓] FTL: v4.3.1
You are updated to the latest version and it looks like your lighttpd problem is also resolved.
That’s weird. It just said there was a new version available.
Thanks for your help. Now I have to fix my pi’s audio problem and it’s vnc problem.
