Hi Everyone!
I'm having some trouble installing Pi-Hole as a docker container. I'm using Portainer for the deployment, but after the container comes up, the WebUI is not available, because of some trouble with lighttpd. Please see the logs below:
Environment information:
Host system is OpenMediaVault 6.0.30-1 (Shaitan) based on Debian 11. Kernel: Linux 5.16.0-0.bpo.4-amd64 x86_64
Docker version:
Client: Docker Engine - Community
Version: 20.10.21
API version: 1.41
Go version: go1.18.7
Git commit: baeda1f
Built: Tue Oct 25 18:02:28 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.21
API version: 1.41 (minimum version 1.12)
Git commit: 3056208
Built: Tue Oct 25 18:00:19 2022
Experimental: false
containerd:
Version: 1.6.9
GitCommit: 1c90a442489720eec95342e1789ee8a5e1b9536f
runc:
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
docker-init:
Version: 0.19.0
GitCommit: de40ad0
Portainer version: Standalone 20.10.21
Compose file:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
# - "67:67/udp" Only required if you are using Pi-hole as your DHCP server
- "80:80/tcp"
environment:
TZ: 'Europe/Budapest'
# WEBPASSWORD: 'set a secure password here or it will be random'
volumes:
- '/srv/dev-disk-by-uuid-1acdc048-0104-4950-ad77-b2ce1eb6df8c/dockerfiles/appdata/pihole/etc-pihole:/etc/pihole'
- '/srv/dev-disk-by-uuid-1acdc048-0104-4950-ad77-b2ce1eb6df8c/dockerfiles/appdata/pihole/etc-dnsmasq.d:/etc/dnsmasq.d'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
restart: unless-stopped
Container Logs:
[i] All config checks passed, cleared for startup ...
[i] Docker start setup complete
[i] pihole-FTL (no-daemon) will be started as pihole
s6-rc: info: service _startup successfully started
s6-rc: info: service pihole-FTL: starting
s6-rc: info: service pihole-FTL successfully started
s6-rc: info: service lighttpd: starting
s6-rc: info: service lighttpd successfully started
s6-rc: info: service _postFTL: starting
s6-rc: info: service _postFTL successfully started
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Stopping lighttpd
lighttpd: no process found
[i] Creating new gravity database
[i] Migrating content of /etc/pihole/adlists.list into new database
[i] Preparing new gravity database...
[i] Using libz compression
[i] Status: Pending...Stopping lighttpd
[i] Analyzed 158531 domains
[i] Creating new gravity databases...
[✓] Creating new gravity databases
[i] Storing downloaded domains in new gravity database...Stopping lighttpd
[✓] Storing downloaded domains in new gravity database
[i] Building tree...
[✓] Building tree
[i] Swapping databases...
[✓] Swapping databases
[✓] The old database remains available.
Stopping lighttpd
[i] Number of gravity domains: 158531 (158531 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[i] Cleaning up stray matter...
[✓] Cleaning up stray matter
[✗] DNS service is NOT running
Stopping lighttpd
Stopping lighttpd
Pi-hole version is v5.14.1 (Latest: v5.14.1)
AdminLTE version is v5.17 (Latest: v5.17)
FTL version is v5.19.1 (Latest: v5.19.1)
Container tag is: 2022.11
Stopping lighttpd
Stopping lighttpd
Stopping lighttpd
Stopping lighttpd
The last two lines iterates further.
Lighttpd error log:
2022-11-17 09:54:02: server.c.1513) server started (lighttpd/1.4.59)
2022-11-17 09:54:02: gw_backend.c.475) unlink /run/lighttpd/php.socket-0 after connect failed: Permission denied
2022-11-17 09:54:02: gw_backend.c.503) bind failed for: unix:/run/lighttpd/php.socket-0: Permission denied
2022-11-17 09:54:02: gw_backend.c.1655) [ERROR]: spawning gw failed.
2022-11-17 09:54:02: server.c.1517) Configuration of plugins failed. Going down.
I've tried to check the php.socket-0 file permissions, but wasn't able to locate the file in that directory:
root@5b18455728d9:/run/lighttpd# ls -la
total 16
drwxr-xr-x+ 1 www-data www-data 4096 Nov 14 23:36 .
drwxr-----+ 1 root root 4096 Nov 17 10:09 ..
I created a debug file and uploaded to you, token is: https://tricorder.pi-hole.net/QrmXyldX/
Honestly this is the farthest where my basic Linux skill took me, so I would like to kindly ask for your help what could be the possible cause of this issue.
Thank you very much in advance!
