I'm not new to Pi-Hole, but I've not used it on cloud instances before.
I can't get the Pi-Hole web interface through IPsec VPN (DNS works). The identical setup works fine on another cloud instance through a public IP address through the public internet.
Setup: Two subnets on Oracle Cloud for testing.
docker run --rm -d \
--name pihole \
-p 53:53/tcp -p 53:53/udp \
-p 80:80 \
-e TZ="Europe/London" \
-e WEBPASSWORD='admin' \
-v "${PIHOLE_BASE}/etc-pihole:/etc/pihole" \
-v "${PIHOLE_BASE}/etc-dnsmasq.d:/etc/dnsmasq.d" \
--dns=127.0.0.1 \
--hostname pi.hole \
-e VIRTUAL_HOST="$(hostname -s)" \
-e PROXY_LOCATION="$(hostname -s)" \
-e FTLCONF_LOCAL_IPV4="$(hostname --ip-address)" \
pihole/pihole:latest
Public subnet running Pi-Hole in docker container on Oracle Linux. Firewall - open all ports and protocols to my home static public IP address. Everything works fine. DNS and web interface.
Private subnet. Exactly the same as above, but in a private subnet accessible through IPsec VPN. No response from web page. DNS requests work fine.
I thought it was an issue with the VPN until I typed http://10.10.1.10/admin/loginn.php
instead of http://10.10.1.10/admin/login.php
and got a 404 page not found from the lighttp web server.
Also, I can see the web interface through the terminal lynx browser and I can curl http://10.10.1.10/admin/login.php
and see it too.
I haven't got much experience with Oracle Linux (essentially CentOS), which has SELinux enabled and has an iptables firewall. I mostly use Debian or CentOS with these disabled, but I don't want to do that anymore (and it doesn't seem to help when I do).
Any ideas?
