Web Interface not reachable at pi.hole / Steam Deck is not seeing device via SSH
My Pi-hole is operating fine from what I can tell, however, the web interface is not coming up at all when trying to reach http://pi.hole locally, and on my Steam Deck only, I'm unable to ssh into it bc it's not even being found, despite being on the same network as all of my other devices. Other machines are finding the Pi Hole just fine via SSH.
Running latest Pihole on an RPI400 connected to my home network using Google Wifi 6E Routers. No changes were made to my configuration at all and just yesterday I was monitoring traffic just fine via pi.hole in my local network.
I have had this stably running for years now, and I only did a recent pihole update just to check if any new definitions had been released...
My Tricorder debug token: https://tricorder.pi-hole.net/FW8YqgJL
The correct URL is http://pi-hole/admin (or http://192.168.86.153/admin, if you use the IP).
Thanks for this! I was able to reboot my rpi and get it back to resolving properly at pi.hole instead of the IP address. Weird blip but it's all fixed now - this is good to close =)
