Web interface loads black screen
Web interface loads with color graphs and visible text
Web interface loads black screen with missing graphs, grayed out text and strange layout.
8dxhi38zwx
Have you tried a repair with pihole -r yet?
yes i tried pihole -r, the repair option with no change. i noticed these chages to the web interface after i updated pihole. Just prior to the update i use
sudo apt-get update && sudo apt-get dist-upgrade -y
then autoremove.
this is the protocol i always follow with updates.
New debug log:
ittree3d7q
Tried repair and left same settings. No change.
First off it looks like you configured IPv6, but now your network does not support IPv6 internet access. Run pihole -r to reconfigure without IPv6. Also, you have IPv6 upstream servers which you will not be able to reach, so those can be removed.
Open the dev tools in your browser (F12) and check if there's any errors in the Console or Network tabs (refresh to show network requests).
I tried the dev tools in the browser (F12) and saw many errors. I ended up reinstalling with one of my backup raspbian images, then updated and upgraded the pi and pihole. I removed the IPv6 upstream servers and reconfigured with the pihole -r command. It works perfectly.
Thank you.
