Web interface is unreachable, but the pihole is working
SOLVED by going to the correct ip. 192.168.0.116 instead of 192.168.0.166
I would like to access the Pihole webinterface/GUI at 192.168.0.166/admin
I get a ERR_CONNECTION_TIMED_OUT when going to 192.168.0.166/admin
The Pihole is blocking ads and I can see that it's working when typing pihole -c
https://tricorder.pi-hole.net/FYatBKFY/
I've run sudo service lighttpd restart but that didnt help.
When running sudo service pihole-FTL status I get this log:
     Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2023-04-16 13:54:30 CEST; 25min ago
    Process: 5035 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
   Main PID: 5048 (pihole-FTL)
      Tasks: 19 (limit: 415)
        CPU: 15.667s
             └─5048 /usr/bin/pihole-FTL -f
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.384 5048M]    PIHOLE_PTR: internal PTR generation enabled (pi.hole)
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.384 5048M]    ADDR2LINE: Enabled
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.384 5048M]    REPLY_WHEN_BUSY: Drop queries when the database is busy
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.385 5048M]    BLOCK_TTL: 2 seconds
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.385 5048M]    BLOCK_ICLOUD_PR: Enabled
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.385 5048M]    CHECK_LOAD: Enabled
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.386 5048M]    CHECK_SHMEM: Warning if shared-memory usage exceeds 90%
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.386 5048M]    CHECK_DISK: Warning if certain disk usage exceeds 90%
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.387 5048M] Finished config file parsing
Apr 16 13:54:30 lotte pihole-FTL[5048]: [2023-04-16 13:54:30.388 5048M] Crea
Your debug log shows Pi-hole's webserver lighttpd to be up and running:
*** [ DIAGNOSING ]: Lighttpd configuration test
[✓] No error in lighttpd configuration
*** [ DIAGNOSING ]: Dashboard headers
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
Your debug log shows your Pi-hole host to live at 192.168.0.116, which doesn't seem to be the address you have been using:
Try http://192.168.0.116/admin or http://pi.hole/admin instead.
Wow, I feel stupid now. Visiting the correct address helps :smiley:
Thank you very much.
Solved.
Don't be too harsh on yourself. :wink:
Sometimes, you just need that second pair of eyes.
