To whom this concerns,
Please, can the team add Web Interface - API Settings to teleporter backup, I was under the impression that the Web Interface - API Settings was added to the Teleporter, only to find this is not the case. I will have to put the information back in.
Thanks, in advance.
All Pi-hole options are stored in /etc/pihole/pihole.toml.
This file is the main config file and it is included in every Teleporter file.
What exactly did you add to Web Interface - API Settings and now are missing?
Also, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
Just the exclusion section, before, was filled, however I had to reinstall Raspberry Pi and the Pi-hole with no issue, but the backup was missing this section.
Found the cause, it was me. sorry to waste your time.
