I've been trying to get a debug token but the output of the pihole -d
command seems to be stuck since more than 30 minutes.
I am having the same issue described in: https://discourse.pi-hole.net/t/web-interface-403-forbidden-blocking-is-working/20327.
It appears that the issue was solved by running:
sudo dpkg -P lighttpd
However when I run the command I am getting an error and I am not able to continue further:
dpkg: problemi con le dipendenze impediscono la rimozione di lighttpd:
lighttpd-mod-openssl dipende da lighttpd (= 1.4.59-1+deb11u2).
lighttpd-mod-deflate dipende da lighttpd (= 1.4.59-1+deb11u2).dpkg: errore nell'elaborare il pacchetto lighttpd (--purge):
problemi con le dipendenze - rimozione non possibile
Si sono verificati degli errori nell'elaborazione:
lighttpd
It is basically saying that it is not possible to purge the packet since there are some dependencies. How can I continue?
Thanks for the help
