Web Dashboard refusing to connect
My diagnosis log is at: https://tricorder.pi-hole.net/0tB8CEj7/
I'm running PiHole on a completely vanilla Raspberry Pi 3, with its Raspbian OS. It's currently set as my router's only DNS server.
The web dashboard was working just fine at pi.hole/admin, and then I upgraded from... a very old version, to whatever is most-current, and now neither that address nor 192.168.0.2/admin/ are responding to browser queries.
Any suggestions, aside from "starting over again"?
Pi-hole v6 uses a completely different web server, embedded into pihole-FTL.
When you upgraded, the previous web server was still running, so Pi-hole v6 installer changed the web interface port to 8080. Also, Pi-hole v6 offers https, on port 443:
[✓] tcp:0.0.0.0:8080 is in use by pihole-FTL
[✓] tcp:0.0.0.0:443 is in use by pihole-FTL
At the moment you can access the web interface using http://192.168.0.2:8080/admin or https://192.168.0.2/admin.
If you want to change the port back to the default one, run this command:
pihole-FTL --config webserver.port '80o,443os'
Apparently I completely missed that memo. Thank you!
