Log into PiHole Web UI and be able to manage the PiHole
login page always loops right back to the login page. If an incorrect password is used it will fail, but correct password just loops. Used pihole -a -p to set no password and that works, but then I cannot make changes. Used pihole -r to repair with no change. Then used pihole -r to reconfigure and still no change.
Pi-hole [v5.18.2]
FTL [v5.25.1]
Web Interface [v5.21]
I suppose (but not sure) it started just after an apt-get upgrade.
*** [ DIAGNOSING ]: Disk usage
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.7G 3.6G 0 100% /
When you login PHP is not able to save the session file (there is no space). Then, the next page tries to verify the login, but no session is found and the function redirects to the login page.
2024-04-01 07:45:06: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/sessions) in Unknown on line 0
2024-04-01 07:45:06: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: fread(): Length parameter must be greater than 0 in /var/www/html/admin/scripts/pi-hole/php/persistentlogin_token.php on line 48
2024-04-01 07:45:06: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Unknown: write failed: No space left on device (28) in Unkn
Dang knew it would be something I missed. I saw that error in the web admin, so I cleared up some logs and got it confirm the log size was 0, but it still has the same issue. Maybe I didn't fully clear them up or could the line you reference have been before I cleared them. Can you point me in the right direction to fully clear up space and prevent it from filling again if it is the issue?
The SD card is actually a 32G card. My top couple logs are:
451M /var/log
382M /var/log/journal/3f1f577d86464a95a8ba216a90029a02
29M /var/log/syslog
I am thinking I may be better off with a fresh format of the drive or a different one. I let a coworker format the drive for me and install the OS, I am thinking he didn't use the full cards available space or something. Thank you for pointing me in the right direction!
