I'm trying to use pihole (dockerized, behind traefik) with homer which is a dashboard, which accesses the pihole api to get stats. But the CORS is preventing this call. I added CORS headers in traefik, but now the api.php returns a Failed CORS: homer_fqdn vs ip,pihole_fqdn. While using with nginx, I bypassed this with a custom fastcgi_param HTTP_ORIGIN "";, but cant seem to figure out for lighttpd 15-fastcgi-php.conf.
What is the right way to get CORS working?
For my pi-hole docker instances, I set the CORS hosts as follows:
CORS_HOSTS=example.com,homer.example.com,homeassistant.example.com
For my traefik docker instance, I created a file called "cors.yaml" with the following:
http:
middlewares:
example-com-cors:
headers:
accessControlAllowHeaders: "*"
accessControlAllowMethods:
- GET
- OPTIONS
- PUT
accessControlAllowOriginListRegex:
- https://(.*)?example\.com(.*)
accessControlMaxAge: 100
addVaryHeader: true
My homer compose.yaml file - and any other containers that need to enable CORS - has the following labels added:
labels:
# Traefik
- "traefik.enable=true"
- "traefik.http.routers.homer-rtr.rule=Host(`${HOSTNAME1}.${DOMAINNAME}`)"
- "traefik.http.routers.homer-rtr.entrypoints=websecure"
- "traefik.http.routers.homer-rtr.middlewares=example-com-cors@file"
- "traefik.http.routers.homer-rtr.service=homer-srv"
- "traefik.http.routers.homer-rtr.tls=true"
- "traefik.http.services.homer-srv.loadbalancer.server.port=${WEBPORT1}"
- "traefik.http.services.homer-srv.loadbalancer.server.scheme=http"
Here are my labels for one of my pi-hole instances:
labels:
- "traefik.http.routers.pihole-1-rtr.rule=Host(`${HOSTNAME}.${DOMAINNAME}`)"
- "traefik.http.routers.pihole-1-rtr.entrypoints=websecure"
- "traefik.http.routers.pihole-1-rtr.middlewares=example-com-cors@file"
- "traefik.http.routers.pihole-1-rtr.service=pihole-1-srv"
- "traefik.http.routers.pihole-1-rtr.tls=true"
- "traefik.http.services.pihole-1-srv.loadbalancer.server.port=${WEBPORT}"
- "traefik.http.services.pihole-1-srv.loadbalancer.server.scheme=http"
That has resolved the issue for any target that requires CORS.
