OK I have an out-of-the-ordinary request. I want to BLOCK Netflix....not allow it ![]()
Kids spend way too much time watching netflix. We have cancelled our account, but muy daughter has since started using a friends account so now I would like to just block access to Netflix completely. I tried adding netflix.com with a wildcard, but didnt seem to work. Anyone know of a way to block access completely?
Have you checked the domains which netflix uses? Are you able to visit any *.netflix.com sites?
Add
*nflxso.net
*nflxext.com
*nflximg.com
Using the wildcard
BTW, you should input them into the wildcard list without the *.
Had to add the *. silly forum was messing whit it ![]()
@Tntdruid I admin-edited your post to remove the .
I believe the suggestion by Tntdruid did the trick!
