Vodafone HHG2500 DNS resolution problems ?router problem
Installed PiHole today on a raspberry pi 2 B+ new raspian buster lite install connected to vodafone Vox 2.5 router by ethernet. Expected it to work.
When I replace the vodafone router default DNS server with the IP of my pihole I lose internet connection for connected clients with DNS failure. I have enabled the 'listen to all' option in admin console and have tried both with and without DHCP server running on pihole. Same result with both.
Token before disabling DNS 8.8.4.4 - https://tricorder.pi-hole.net/h0ykhtubuz
Token after making sure PiHole is only DNS address - https://tricorder.pi-hole.net/ku9ul5wvn4
I am having the same issue.
