I have Pi-Hole ruining on a raspberry pi 4 / Ubuntu server connected to a Ubiquiti UDM PRO, it's work fine on my LAN, but won't work in any VLANs
Firewall rules created :
WAN_OUT accept IP: Pi-Hole destination Port 53
LAN_IN accept all VLAN to Pi-Hole IP / Pi-hole Port
GUEST_IN > same as LAN_IN (one VLAN is guest)
on the Pi-hole web interface, I only have eth0 listed in the network tab
Still in Pi-Hole, I enabled Conditional Forwarding, with my LAN gateway IP
Am'I expected to enable DHCP in UniFi with the PI-hole address?
coming back in my Ubuntu Server (Pi-Hole), I don't have interfaces.d but 50-cloud-init.yaml
so far I did this :
ubuntu@ubuntu:~$ sudo mv /etc/netplan/50-cloud-init.yaml /etc/netplan/01-netcfg.yaml
ubuntu@ubuntu:~$ sudo nano /etc/netplan/01-netcfg.yaml
but I'm worried about the config I gonna enter (I only have SSH to connect to the Raspberry Pi 4 and I don't want to lost connection)
ubuntu@ubuntu:~$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
Here is my curent 01-netcfg.yaml
GNU nano 4.8 /etc/netplan/01-netcfg.yaml
# This file is generated from information provided by the datasource. Changes
# to it will not persist across an instance reboot. To disable cloud-init's
# network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
ethernets:
eth0:
dhcp4: true
optional: true
version: 2
- how can I set a static IP of 192.168.1.70 (only if required, I don't really mind having a dynamic IP as the network DHCP already have an IP assignment)
- how can I add VLAN 20 IP range 192.168.2.1/24 and VLAN 30 192.168.8.1/24
