I am expecting the previous 7 days sticky login I used to have in V5 and no auto logout of the web interface.
Also, I do not expect the new message asking to force HTTPs as it was never needed in V5 and I run on my local network
As of the upgrade to V6 I observed 2 issues:
The Web interface times out / logs me out every few minutes, the option to stay logged in for 7 days no longer appears
The browser shows an error that HTTPS is not enabled and my session isn't secured, I run my pihole instance on the local network and never needed HTTPS
The webserver timeout is listed in the /etc/piole/pihole.toml file. Its default is 1800 seconds. You can change the value there.
[webserver.session]
# Session timeout in seconds. If a session is inactive for more than this time, it will
# be terminated. Sessions are continuously refreshed by the web interface, preventing
# sessions from timing out while the web interface is open.
# This option may also be used to make logins persistent for long times, e.g. 86400
# seconds (24 hours), 604800 seconds (7 days) or 2592000 seconds (30 days). Note that
# the total number of concurrent sessions is limited so setting this value too high
# may result in users being rejected and unable to log in if there are already too
# many sessions active.
timeout = 1800
Yeah that's correct. I can't remember where I saw it (might be internal), but I saw some discussion around maybe making this warning/message less prominent.
HTTPs is great, but in almost all cases it's overkill on a local (closed) network. Unless you really don't trust the people you live with.
Since I have got other stuff running with Self Signed Certificates like OPNsense and the UniFi Controller the fact that Pi-Hole v6 has one too was a nice surprise for me
So one of the first things I did was bind it only to port 443
