V6 Only FTL is updated not Core and Webinterface
sudo pihole -up should update FTL, Core and Webinterface
Only the FTL is update not the Core and Webinterface
Core version is v6.0.3 (Latest: v6.0.5)
Web version is v6.0.1 (Latest: v6.0.2)
FTL version is v6.0.4 (Latest: v6.0.4)
[✓] Version: v6.0.3
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v6.0.3-0-g0e6d9e74
[✓] Version: v6.0.1
[i] Remotes: origin https://github.com/pi-hole/adminLTE.git (fetch)
origin https://github.com/pi-hole/adminLTE.git (push)
[i] Branch: master
[i] Commit: v6.0.1-0-g42e7279a
[✓] Version: v6.0.4
[i] Branch: master
[i] Commit: b7eb53bf
[✓] Detected ARMv7 (or newer) architecture (v7
Application)
[i] Latest FTL binary already installed (v6.0.4), verifying integrity...
[i] Local binary up-to-date. No need to download!
[✓] Installing scripts from /etc/.pihole
[✓] Installing latest Cron script
[i] Installing latest logrotate script...
[i] Existing logrotate file found. No changes made.
[i] man not installed
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[i] Restarting services...
[i] Enabling pihole-FTL service to start on reboot...
prefer not to hope its not needed.
Same problem here last week (updated from v5 to v6 including keeping settings):
Core version is v6.0 (Latest: v6.0.4)
Web version is v6.0 (Latest: v6.0.1)
FTL version is v6.0.2 (Latest: v6.0.2)
now again:
Core version is v6.0.4 (Latest: v6.0.5)
What did help was to switch to the 'dev' and back to 'master', but that's not the best solution ofcourse. Can always do a clean install, if there's no better solution.
Debug token:
https://tricorder.pi-hole.net/zscHW4hl/
