v6 Disable pi.hole DNS Record
Hi there,
Crossposting this from Reddit as I think there is a lower liklihood of it getting buried here.
Original link: https://www.reddit.com/r/pihole/comments/1iso0qu/v6_disable_pihole_dns_record/
The issue I am facing:
I updated to v6 a few days ago, and while everything is working swimmingly I'd like to disable the pi.hole DNS record. I have my network configured so that my pihole console uses a private FQDN (ex: https://dns.[domain].[tld]), so the default record is superfluous at this point. Additionally, it seems some clever front-end admins are resolving pi.hole to detect if the system is deployed locally.
I have updated pihole.toml as follows (superfluous lines ommitted):
[dns]
piholePTR = "NONE" #Per suggestion in Reddit thread above
[webserver]
domain = [dns.[domain].[tld]] #actual domain and TLD omitted for privacy
Currently the custom domain is resolving happily, but pi.hole is still resolving successfully. Also, while I did update my piholePTR value above per the suggestion on reddit, I would like the pihole to return the value of my custom record noted above.
I found the following forum posts related to this, though they are multiple years old, and don't seem to provide a good solution in general, nevertheless for v6.
https://discourse.pi-hole.net/t/remove-pi-hole-hostname-completely/62533
https://discourse.pi-hole.net/t/how-to-disable-pi-hole-dns-record/49606/36
Does anybody have any suggestions?
Details about my system:
I am running my pi.hole on a Raspberry Pi 4 Model B r1.5, with the most recent Raspberry Pi OS backed on Bookwork (see below). I do have a custom internal A record reverse-proxied to my Pi-Hole using a Caddy instance running on another machine, and it resolves the pihole dashboard correctly at the moment.
I'm not sure if I understand you correctly, as you haven't supplied any custom DNS records (yet)?
To help my understanding, please provide how Pi-hole currently resolves your aspired name, preferably by means of a dig command output, and how you would like that to be answered instead.
I apologize for the lack of clarity here. My custom DNS records are fully configured and functional, as show below selectively blurred for privacy.
Please note that the dns & dns-adm records are duplicative for a test.
Having my pihole return my custom domain is not critical, and I apologize for mentioning it. My main goal is disabling the https://pi.hole DNS record for the web interface. I'd like it to return NXDOMAIN as though pi.hole has no records.
Relevant dig results as-requested, run from another machine on my network.
tl;dr My custom records work as-expected, I would like pi.hole to return NXDOMAIN
In an attempt to force the desired behavior I have added pi.hole as an explicit record pointing at a false IPv4 address.
Unfortunately it still resolves the web console
dig output
That's much clearer, thank you (and all in one sentence). :wink:
Currently, disabling pi.hole completely to have it return NXDOMAIN isn't possible.
One user has brought up that idea some years ago for Pi-hole v5, but that discussion wasn't followed up by a feature request.
For v5, changing that name would also have meant to change its HTML code in places.
Pi-hole v6 now offers configuration of a webserver.domain which potentially could be leveraged to accomplish such a change, but currently it affects only Pi-hole's web server portion.
If you want to disable pi.hole, you'd have to change Pi-hole's source code and compile your own pihole-FTL, which was what aforementioned user has ultimately opted to do.
If you want Pi-hole to offer this, you should consider to open a Feature Request.
Awesome, appreciate the confirmation.
Apologies if the ask wasn’t concise enough, my job is collaborating with other engineers, and our company’s culture prefers detail & context over brevity. Learned habits, etc.
I’ll open a feature request shortly, and depending on your contribution model, am happy to do the engineering as well. See you on GitHub!
