I am not famiiar with lancache at all, but a while ago, another user had difficulties using a dockered lancache as Pi-hole's upstream DNS. This was caused by lancache handling DNS UDP traffic only, instead of UDP and TCP.
Hey, Appreciate the reply. I fully read that article and verified TCP 53 is in my docker config yml. My primary symptom at the moment is super high query time 1200+ MS for each query.
My setup is slightly different in that I have my Lancache and Pihole servers separated.
If I added the URLs in the host file on pihole to point at lancache would that work? I may be completely wrong, but am not sure how else to mitigate the query slowness.
Another idea, is there anyway I can add URL's to the conditional forwarding in pihole?
I actually was curious if there was any updates for Lancache, after update the docker containers query times dropped quite dramatically, I wonder if there was a memory leak or something causing the process to be super slow. I am still interested in seeing if there is an option to only forward specific URLs to the lancache server to help improve query time even more.
